ONTAP 7-Mode Transition
Copy-free transition project planning worksheets
You can use the copy-free transition planning worksheets to record information about node mapping, SVM mapping, volume mapping, and LIFs to transition. The worksheets are useful when creating a transition project by using the 7-Mode Transition Tool. You should be aware of the guidelines for completing the worksheets.
You can follow these guidelines to complete the worksheets:
  • Map each vFiler unit to an SVM.
    If there are no vFiler units in the 7-Mode controller, map the controller to a single SVM.
  • Record the 7-Mode volume name and the corresponding Data ONTAP volume name.
    The ONTAP volume name might be different from the 7-Mode volume name.
  • Identify the LIFs to be configured on each SVM.
    The IP addresses for the LIFs can either be existing on the 7-Mode system or can be new LIFs.
Node mapping
7-Mode controller Mapped cluster node
SVM and volume mapping
7-Mode controller vFiler unit or controller Mapped SVM 7-Mode volume SVM volume
LIF mapping (7-Mode IP addresses)
7-Mode controller vFiler unit or controller Mapped SVM 7-Mode IP address Netmask Default gateway Home node Home port
LIF mapping (new LIFs)
SVM New IP address Netmask Default gateway Home node Home port
Example
The following table shows an example of completed worksheets for a 7-Mode HA pair with the controllers hostA_7mode and hostB_7mode.
Node mapping
hostA_7mode
cluster1_01
hostB_7mode
cluster1_02
7-Mode controller Mapped cluster node vFiler unit or controller Mapped SVM 7-Mode volume SVM volume
hostA_7mode
cluster1_01
vfilerA
svm1
volA
volA
volB
volB
vfilerB
svm2
vol1
vol_nfs
vol2
vol_cifs
hostB_7mode
cluster1_02
Not applicable
svm3
vol3
vol3
vol4
vol4
vol5
vol5
vol6
vol6
7-Mode controller vFiler unit or controller Mapped SVM Existing 7-Mode IP Netmask Default gateway Home node Home port
hostA_7mode
vfilerA
svm1
192.0.2.129
255.255.255.128
192.40.0.1
cluster1_01
e0a
192.0.2.135
255.255.255.128
192.40.0.1
cluster1_02
e0b
vfilerB
svm2
hostB_7mode
Not applicable
svm3
192.0.2.110
255.255.255.128
192.40.0.1
cluster1_01
e0c
192.0.2.111
255.255.255.128
192.40.0.1
cluster1_02
e0d
svm1
svm2
192.0.2.130
255.255.255.128
192.40.0.1
cluster1_01
e1c
192.0.2.131
255.255.255.128
192.40.0.1
cluster1_02
e1d
svm3
192.0.2.136
255.255.255.128
192.40.0.1
cluster1_01
e0c
192.0.2.137
255.255.255.128
192.40.0.1
cluster1_02
e0d
