ONTAP 7-Mode Transition
Collection and assessment commands
The Inventory Collect Tool (ICT) collects inventory information from controllers, hosts, and FC switches by using a list of commands to generate an inventory XML report; assesses the features and functionalities of these systems; and identifies how these features and functionalities work in the clustered Data ONTAP version that is selected for transition.
ONTAP 7-Mode APIs
  • aggr-list-info
  • cf-status
  • cifs-homedir-paths-get
  • cifs-list-config
  • cifs-nbalias-names-get
  • cifs-share-acl-list-iter-start
  • cifs-share-list-iter-start
  • cifs-status
  • disk-list-info
  • fcp-adapter-list-info
  • fpolicy-list-info
  • igroup-list-info
  • iscsi-interface-list-info
  • iscsi-node-get-name
  • license-list-info
  • license-v2-list-info
  • lun-get-comment
  • lun-list-info
  • lun-map-list-info
  • net-config-get-active
  • nfs-exportfs-list-rules
  • nfs-exportfs-list-rules-2
  • nfs-status
  • options-get
  • options-list-info
  • qtree-list-iter-start
  • quota-list-entries-iter-start
  • quota-report-iter-start
  • registry-list-info-iter-start
  • sis-status
  • snapmirror-get-status
  • snapmirror-list-schedule
  • snapmirror-list-sync-schedule
  • snapshot-get-schedule
  • snapshot-list-info
  • snapshot-volume-info
  • snapvault-primary-relationship-status-list-iter-start
  • snapvault-secondary-relationship-status-list-iter-start
  • snmp-status
  • storage-disk-get-iter
  • system-available-replication-transfers
  • system-get-info
  • system-get-ontapi-version
  • system-get-version
  • useradmin-group-list
  • useradmin-role-list
  • useradmin-user-list
  • vfiler-get-allowed-protocols
  • vfiler-get-status
  • vfiler-list-info
  • volume-charmap-get
  • volume-get-filer-info
  • volume-get-language
  • volume-list-info-iter-start
  • volume-options-list-info
ONTAP 7-Mode CLI
  • cifs shares
  • ic primary show
  • ifconfig -a
  • ifconfig vip
  • ifgrp status
  • ls $volumes_path/metadir/slag/
  • printflag wafl_metadata_visible
  • rdfile $root_vol/etc/cifsconfig_share.cfg
  • rdfile $root_vol/etc/group
  • rdfile $root_vol/etc/hosts
  • rdfile $root_vol/etc/krb5auto.conf
  • rdfile $root_vol/etc/mcrc
  • rdfile $root_vol/etc/netgroup
  • rdfile $root_vol/etc/nsswitch.conf
  • rdfile $root_vol/etc/passwd
  • rdfile $root_vol/etc/resolv.conf
  • rdfile $root_vol/etc/snapmirror.conf
  • rdfile $root_vol/etc/symlink.translations
  • rdfile $root_vol/etc/usermap.cfg
  • rdfile $vfiler_roots/etc/cifsconfig_share.cfg
  • rdfile $vfiler_roots/etc/group
  • rdfile $vfiler_roots/etc/hosts
  • rdfile $vfiler_roots/etc/krb5auto.conf
  • rdfile $vfiler_roots/etc/mcrc
  • rdfile $vfiler_roots/etc/netgroup
  • rdfile $vfiler_roots/etc/nsswitch.conf
  • rdfile $vfiler_roots/etc/passwd
  • rdfile $vfiler_roots/etc/resolv.conf
  • rdfile $vfiler_roots/etc/snapmirror.conf
  • rdfile $vfiler_roots/etc/symlink.translations
  • rdfile $vfiler_roots/etc/usermap.cfg
  • rlm status
  • routed status
  • route -sn
  • setflag wafl_metadata_visible 0
  • setflag wafl_metadata_visible 1
  • snapvault status -l
  • sysconfig -A
  • uptime
  • vfiler status -a
  • vlan stat
ONTAP 7-Mode NetApp Manageability SDK
  • cluster-identity-get
  • cluster-node-get-iter
  • fcp-adapter-get-iter
  • fcp-initiator-get-iter
  • fcp-interface-get-iter
  • lun-get-iter
  • lun-map-get-iter
  • net-interface-get-iter
  • system-get-node-info-iter
  • volume-get-iter
  • vserver-get-iter
Windows
  • `HKEY_LOCAL_MACHINE\\SOFTWARE\\NetApp*
  • HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Uninstall
  • select * from MPIO_Registered_DSM
  • select * from MSCluster_Cluster
  • select * from MSCluster_Disk
  • select * from MSCluster_Node
  • select * from MSCluster_NodeToActiveResource
  • select * from MSCluster_Resource
  • select * from MSCluster_ResourceToDisk
  • select * from MSFC_FCAdapterHBAAttributes
  • select * from MSFC_FibrePortHBAAttributes
  • select * from MSiSCSI_HBAInformation
  • select * from MSiSCSIInitiator_MethodClass
  • select * from Win32_ComputerSystem
  • select * from Win32_DiskDrive
  • select * from Win32_OperatingSystem
  • select * from Win32_PnPSignedDriver where DeviceClass = "SCSIADAPTER"
  • select * from Win32_Product
Linux CLI
  • blkid
  • cat /boot/grub/device.map
  • cat /etc/grub.conf
  • cat /etc/iscsi/initiatorname.iscsi
  • cman_tool nodes
  • cman_tool status
  • df -h
  • dmidecode -t system
  • find /etc -maxdepth 1 -name *-release -type f -print -exec cat -v {} \;
  • for file in /sys/block/sd***; do echo ${file/#\/sys}; scsi_id -p 0x80 -g -x -a -s ${file/#\/sys}; done
  • for file in /sys/class/scsi_host/*; do echo; for ent in ${file}/*; do echo -n "$ent: "; if [ -f "${ent}" ]; then if [ -r "${ent}" ]; then cat -v -s ${ent} 2>/dev/null; if [ "$?" != "0" ]; then echo; fi; fi; else echo; fi; done; done
  • for file in /sys/class/fc_host/*; do echo; for ent in ${file}/*; do echo -n "$ent: "; if [ -f "${ent}" ]; then if [ -r "${ent}" ]; then cat -v -s ${ent} 2>/dev/null; if [ "$?" != "0" ]; then echo; fi; fi; else echo; fi; done; done
  • iscsiadm -m node
  • lsb_release -a
  • lvdisplay -m
  • mount
  • rpm -qa --qf "%{NAME}%{SUMMARY}%{VENDOR}___%{PROVIDEVERSION}\n"
  • sanlun fcp show adapter -v
  • sanlun lun show -pv
  • sanlun lun show -v
  • sanlun version
  • san_version
  • sfdisk -uS -l
  • uname -a
  • vxclustadm nidmap
  • vxclustadm -v nodestate
VMware CLI
  • esxcfg-info -a -F xml
  • esxcfg-mpath -l
  • esxcfg-scsidevs -a
  • esxcfg-scsidevs -l
  • esxcli software vib get
  • find /proc/scsi -type f | while read line; do echo $line; cat $line; done
  • san_version
  • uname -m
  • uname -n
  • /usr/lib/vmware/vmkmgmt_keyval/vmkmgmt_keyval -a
  • /usr/lib/vmware/vm-support/bin/dump-vmdk-rdm-info.sh $vmx_paths
  • vim-cmd /vmsvc/getallvms
  • vim-cmd vmsvc/snapshot.get $vm_ids
  • vmkload_mod -s nmp
  • vmware -l
  • vmware -v
Cisco CLI
  • show fcdomain domain-list
  • show flogi database
  • show switchname
  • show version
  • show vsan
  • show zoneset
  • show zoneset active
  • uname -m
  • nsshow
  • switchshow
  • version
  • zoneshow
  • vmware -l
  • vmware -v
Brocade CLI
  • nsshow
  • switchshow
  • version
  • zoneshow
