ONTAP 7-Mode Transition
ESXi versions and features supported for SAN transitions using 7MTT
Only certain versions and features of ESXi are supported for SAN transitions using the 7-Mode Transition Tool (7MTT).
The following versions and features are supported as listed in the NetApp Interoperability Matrix Tool
  • ESXi 5.0, 5.1, 5.5, and later
    You must upgrade hosts running ESX/ESXi 4.x or earlier to ESX/ESXi 5.0 or later to transition them.
  • VMFS3 and VMFS5 datastores
  • SAN boot configurations
  • RDM (RAW device map) devices
  • All Guest OS supported in the Interoperability Matrix
  • All SAN protocols (FC/FCoE/iSCSI)
