Preparing for transition of FC or FCoE SAN boot LUNs on RHEL hosts
Before you transition an FC or FCoE SAN boot LUN, you must perform specific steps on your Red Hat Enterprise Linux (RHEL) host.
You must have the following information from the Inventory Assessment Workbook:
7-Mode LUN name on which RHEL 5 or RHEL 6 is installed
SCSI device name for the transition LUN
DMMP device name for the transition LUN
Mount directory
File system configured on the DMMP device
UUID number of the /boot partition
Name of the
initridimage
This procedure applies to copy-based transitions and copy-free transitions.
Verify that the DMMP device exists in the /dev/mapper directory:
ls /dev/mapper/ DMMP_device_nameIf you cannot locate the DMMP device, then it might be using an alias or user-friendly name.
Identify the DMMP devices and Logical Volume Manager (LVM) names on which the RHEL 5 or RHEL 6 operating system /boot and root (/) directories are installed:
df - hBy default, RHEL 5 and RHEL 6 are installed on the root (/) partition on the logical volume. If the root partition is installed on the logical volume, then no pretransition changes to the configuration are required.
If the /boot partition is installed on the DMMP device, confirm how the /boot partition is referenced to mount in
/etc/fstabat boot time. -
If the /boot partition is referenced in
/etc/fstabby its DMMP device name, replace the DMMP device name with the file system UUID name. -
Make a backup of the
/etc/fstabfile:cp /etc/fstab /etc/fstab_pre_transition_file_name -
Edit the
/etc/fstabfile to replace the DMMP device name with its respective file system UUID number. -
initrdimage file:cp /boot/initrd_image_file_nameinitrd_image_file_name.bak -
For RHEL 5 only:
In the
/etc/mutipath.conffile, identify the SWAP partition device.In the following example,
/dev/VolGroup00/LogVol01is the SWAP partition device:/dev/VolGroup00/LogVol01 swap swap defaults 0 0 -
Create a label for mounting the swap partition:
swapoff swap-partition_devicemkswap -L label-for-swapswap-partition-deviceswapon swap-partition_device -
Replace the SWAP partition device name in the
/etc/fstabfile with THE SWAP label.The updated line in the
/etc/fstabfile should be as follows:LABEL=SwapPartition swap swap defaults 0 0
Re-create the initrd image.
For RHEL5:
mkinitrd -f/boot/ initrd-"'uname-r'".img 'uname-r' --with multipath -
For RHEL 6:
dracut --force --add multipath --verbose
Restart the host to boot from the new
initrdimage.
Related information
