Powering on the equipment at the disaster site (MetroCluster IP configurations)
PDF of this doc site
- Install a fabric-attached MetroCluster
- Install a MetroCluster IP configuration
- Install a stretch MetroCluster configuration
- Transition from MetroCluster FC to MetroCluster IP
Creating your file...
Your file is ready
You must power on the disk shelves and MetroCluster IP switches components at the disaster site. The controller modules at the disaster site remain at the LOADER prompt.
About this task
The examples in this procedure assume the following:
Site A is the disaster site.
Site B is the surviving site.
Steps
Turn on the disk shelves at the disaster site and make sure that all disks are running.
Turn on the MetroCluster IP switches if they are not already on.
