ONTAP MetroCluster
Cabling the FC-VI and HBA ports in an eight-node fabric-attached MetroCluster configuration with array LUNs
Contributors netapp-thomi netapp-aoife
If you are setting up an eight-node fabric-attached MetroCluster configuration with array LUNs, you must cable the FC-VI ports and the HBA ports to the switch ports.
About this task
Step
  1. Cable the FC-VI ports and HBA ports from each controller to the ports on alternate FC switches. Refer to the following tables:
Cabling configurations for FibreBridge 7500N or 7600N using both FC ports
Configurations using FibreBridge 7500N or 7600N using both FC ports (FC1 and FC2)
MetroCluster 1 or DR Group 1
Component
Port
Brocade switch models 6505, 6510, 6520, 7810, 7840, G610, G620, G620-1, G630, G630-1, and DCX 8510-8
Brocade switch G720
Connects to FC_switch…​
Connects to switch port…​
controller_x_1
FC-VI port a
1
0
0
FC-VI port b
2
0
0
FC-VI port c
1
1
1
FC-VI port d
2
1
1
HBA port a
1
2
8
HBA port b
2
2
8
HBA port c
1
3
9
HBA port d
2
3
9
controller_x_2
FC-VI port a
1
4
4
FC-VI port b
2
4
4
FC-VI port c
1
5
5
FC-VI port d
2
5
5
HBA port a
1
6
12
HBA port b
2
6
12
HBA port c
1
7
13
HBA port d
2
7
13
Stack 1
bridge_x_1a
FC1
1
8
10
FC2
2
8
10
bridge_x_1B
FC1
1
9
11
FC2
2
9
11
Stack 2
bridge_x_2a
FC1
1
10
14
FC2
2
10
14
bridge_x_2B
FC1
1
11
15
FC2
2
11
15
Stack 3
bridge_x_3a
FC1
1
12*
16
FC2
2
12*
16
bridge_x_3B
FC1
1
13*
17
FC2
2
13*
17
Stack y
bridge_x_ya
FC1
1
14*
20
FC2
2
14*
20
bridge_x_yb
FC1
1
15*
21
FC2
2
15*
21
* Ports 12 through 15 are reserved for the second MetroCluster or DR group on the Brocade 7840 switch.
Note: Additional bridges can be cabled to ports 16, 17, 20 and 21 in G620, G630, G620-1 and G630-1 switches.
After you finish
You should cable the ISLs between the FC switches across the MetroCluster sites.
Cabling configurations for Cisco 9250i
Cisco 9250i*
Component
Port
Switch 1
Switch 2
controller_x_1
FC-VI port a
1
FC-VI port b
1
HBA port a
2
HBA port b
2
HBA port c
3
HBA port d
3
controller_x_2
FC-VI port a
4
FC-VI port b
4
HBA port a
5
HBA port b
5
HBA port c
6
HBA port d
6
controller_x_3
FC-VI port a
7
FC-VI port b
7
HBA port a
8
HBA port b
8
HBA port c
9
HBA port d
9
controller_x_4
FC-VI port a
10
FC-VI port b
10
HBA port a
11
HBA port b
11
HBA port c
13
HBA port d
13
After you finish
