ONTAP MetroCluster
Transitioning the MetroCluster FC nodes
Contributors netapp-martyh netapp-aoife netapp-thomi NetAppZacharyWambold
You must gather information from the existing MetroCluster FC nodes, send an autosupport message announcing the start of maintenance, and transition the nodes.
Gathering information from the existing controller modules before the transition
Before transitioning, you must gather information for each of the nodes.
This task is performed on the existing nodes:
  • node_A_1-FC
  • node_B_1-FC
    1. Gather the output for the commands in the following table.
Category Commands Notes
License
system license show
Shelves and numbers of disks in each shelf and flash storage details and memory and NVRAM and and network cards
system node run -node node_name sysconfig
Cluster network and node management LIFs
system node run -node node_name sysconfig network interface show -role "cluster,node-mgmt,data"
SVM information
vserver show
Protocol information
nfs show iscsi show cifs show
Physical ports
network port show -node node_name -type physical network port show
Failover Groups
network interface failover-groups show -vserver vserver_name
Record the names and ports of failover groups that are not clusterwide.
VLAN configuration
network port vlan show -node node_name
Record each network port and VLAN ID pairing.
Interface group configuration
network port ifgrp show -node node_name -instance
Record the names of the interface groups and the ports assigned to them.
Broadcast domains
network port broadcast-domain show
IPspace
network ipspace show
Volume info
volume show and volume show -fields encrypt
Aggregate Info
storage aggregate show and storage aggr encryption show andstorage aggregate object-store show
Disk ownership information
Encryption
storage failover mailbox-disk show and security key-manager backup show
Also preserve the passphrase used to enable key-manager. In the case of external key-manager you will need the authentication information for the client and server.
Encryption
security key-manager show
Encryption
security key-manager external show
Encryption
systemshell local kenv kmip.init.ipaddr ip-address
Encryption
systemshell local kenv kmip.init.netmask netmask
Encryption
systemshell local kenv kmip.init.gateway gateway
Encryption
systemshell local kenv kmip.init.interface interface
Sending a custom AutoSupport message prior to maintenance
Before performing the maintenance, you should issue an AutoSupport message to notify NetApp technical support that maintenance is underway. This prevents them from opening a case on the assumption that a disruption has occurred.
This task must be performed on each MetroCluster site.
  1. To prevent automatic support case generation, send an Autosupport message to indicate maintenance is underway.
    1. Issue the following command: system node autosupport invoke -node * -type all -message MAINT=maintenance-window-in-hours
      maintenance-window-in-hours specifies the length of the maintenance window, with a maximum of 72 hours. If the maintenance is completed before the time has elapsed, you can invoke an AutoSupport message indicating the end of the maintenance period:system node autosupport invoke -node * -type all -message MAINT=end
    2. Repeat the command on the partner cluster.
Transitioning, shutting down, and removing the MetroCluster FC nodes
In addition to issuing commands on the MetroCluster FC nodes, this task includes physical uncabling and removal of the controller modules at each site.
This task must be performed on each of the old nodes:
  • node_A_1-FC
  • node_B_1-FC
    1. Stop all client traffic.
    2. On either of the MetroCluster FC nodes, for example node_A_1-FC, enable transition.
      1. Set the advanced privilege level: set -priv advanced
      2. Enable transition: metrocluster transition enable -transition-mode disruptive
      3. Return to admin mode: set -priv admin
    3. Unmirror the root aggregate by deleting the remote plex of the root aggregates.
      1. Identify the root aggregates: storage aggregate show -root true
      2. Display the pool1 aggregates: storage aggregate plex show -pool 1
      3. Delete the local plex of the root aggregate: aggr plex delete aggr-name -plex plex-name
      4. Offline the remote plex of the root aggregate: aggr plex offline root-aggregate -plex remote-plex-for-root-aggregate
        For example:
         # aggr plex offline aggr0_node_A_1-FC_01 -plex plex4
    4. Confirm the mailbox count, disk autoassign, and transition mode before proceeding using the following commands on each controller:
      2. Confirm that only three mailbox drives are shown for each controller module: storage failover mailbox-disk show
      4. Confirm that the transition mode is disruptive: metrocluster transition show
    5. Check for any broken disks: disk show -broken
    6. Remove or replace any broken disks
    7. Confirm aggregates are healthy using the following commands on node_A_1-FC and node_B_1-FC:storage aggregate showstorage aggregate plex show
      The storage aggregate show command indicates that the root aggregate is unmirrored.
    8. Check for any VLANs or interface groups: network port ifgrp show``network port vlan show
      If none are present, skip the following two steps.
    9. Display the list of LIfs using VLANs or ifgrps: network interface show -fields home-port,curr-port``network port show -type if-group | vlan
    10. Remove any VLANs and interface groups.
      You must perform these steps for all LIFs in all SVMs, including those SVMs with the -mc suffix.
      1. Move any LIFs using the VLANs or interface groups to an available port: network interface modify -vserver vserver-name -lif lif_name -home- port port
      2. Display the LIFs that are not on their home ports: network interface show -is-home false
      3. Revert all LIFs to their respective home ports: network interface revert -vserver vserver_name -lif lif_name
      4. Verify that all LIFs are on their home ports: network interface show -is-home false
        No LIFs should appear in the output.
      5. Remove VLAN and ifgrp ports from broadcast domain:: network port broadcast-domain remove-ports -ipspace ipspace -broadcast-domain broadcast-domain-name -ports nodename:portname,nodename:portname,..
      6. Verify that all the vlan and ifgrp ports are not assigned to a broadcast domain: network port show -type if-group | vlan
      7. Delete all VLANs: network port vlan delete -node nodename -vlan-name vlan-name
      8. Delete interface groups: network port ifgrp delete -node nodename -ifgrp ifgrp-name
    11. Move any LIFs as required to resolve conflicts with the MetroCluster IP interface ports.
      You must move the LIFs identified in step 1 of Mapping ports from the MetroCluster FC nodes to the MetroCluster IP nodes.
      1. Move any LIFs hosted on the desired port to another port: network interface modify -lif lifname -vserver vserver-name -home-port new-homeport``network interface revert -lif lifname -vserver vservername
      2. If necessary, move the destination port to an appropriate IPspace and broadcast domain. network port broadcast-domain remove-ports -ipspace current-ipspace -broadcast-domain current-broadcast-domain -ports controller-name:current-port``network port broadcast-domain add-ports -ipspace new-ipspace -broadcast-domain new-broadcast-domain -ports controller-name:new-port
    12. Halt the MetroCluster FC controllers (node_A_1-FC and node_B_1-FC): system node halt
    13. At the LOADER prompt, synchronize the hardware clocks between the FC and IP controller modules.
      1. On the old MetroCluster FC node (node_A_1-FC), display the date: show date
      2. On the new MetroCluster IP controllers (node_A_1-IP and node_B_1-IP), set the date shown on original controller: set date mm/dd/yy
      3. On the new MetroCluster IP controllers (node_A_1-IP and node_B_1-IP), verify the date: show date
    14. Halt and power off the MetroCluster FC controller modules (node_A_1-FC and node_B_1-FC), FC-to-SAS bridges (if present), FC switches (if present) and each storage shelf connected to these nodes.
    15. Disconnect the shelves from the MetroCluster FC controllers and document which shelves are local storage to each cluster.
      If the configuration uses FC-to-SAS bridges or FC back-end switches, disconnect and remove them.
    16. In Maintenance mode on the MetroCluster FC nodes (node_A_1-FC and node_B_1-FC), confirm no disks are connected: disk show -v
    17. Power down and remove the MetroCluster FC nodes.
At this point, the MetroCluster FC controllers have been removed and the shelves are disconnected from all controllers.
transition 2n remove fc nodes
