Mount or unmount existing volumes in the NAS namespace
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
A volume must be mounted on the NAS namespace before you can configure NAS client access to data contained in the storage virtual machine (SVM) volumes. You can mount a volume to a junction point if it is not currently mounted. You can also unmount volumes.
If you unmount and take a volume offline, all data within the junction point, including data in volumes with junction points contained within the unmounted volume's namespace, are inaccessible to NAS clients.
To discontinue NAS client access to a volume, it is not sufficient to simply unmount the volume. You must take the volume offline, or take other steps to ensure that client-side file handle caches are invalidated. For more information, see the following Knowledge Base article: |
When you unmount and offline a volume, data within the volume is not lost. Additionally, existing volume export policies and SMB shares created on the volume or on directories and junction points within the unmounted volume are retained. If you remount the unmounted volume, NAS clients can access the data contained within the volume using existing export policies and SMB shares.
Perform the desired action:
If you want to… Enter the commands… Mount a volume
volume mount -vserver svm_name -volume volume_name -junction-path junction_path
Unmount a volume
volume unmount -vserver svm_name -volume volume_name
volume offline -vserver svm_name -volume volume_name
Verify that the volume is in the desired mount state:
volume show -vserver svm_name -volume volume_name -fields state,junction-path,junction-active
The following example mounts a volume named “sales” located on SVM “vs1” to the junction point “/sales”:
cluster1::> volume mount -vserver vs1 -volume sales -junction-path /sales cluster1::> volume show -vserver vs1 state,junction-path,junction-active vserver volume state junction-path junction-active --------- ---------- -------- --------------- ---------------- vs1 data online /data true vs1 home4 online /eng/home true vs1 sales online /sales true
The following example unmounts and takes offline a volume named “data” located on SVM “vs1”:
cluster1::> volume unmount -vserver vs1 -volume data cluster1::> volume offline -vserver vs1 -volume data cluster1::> volume show -vserver vs1 -fields state,junction-path,junction-active vserver volume state junction-path junction-active --------- ---------- --------- --------------- --------------- vs1 data offline - - vs1 home4 online /eng/home true vs1 sales online /sales true
