Clone LUNs with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create a temporary copy of a LUN for testing or to make a copy of your data available to additional users without providing them access to the production data. LUN clones enable you to create multiple readable and writable copies of a LUN.
Before you begin
  • You must have installed the FlexClone license on the storage system.
  • When space reservation is disabled on a LUN, the volume that contains the LUN must have enough space to accommodate changes to the clone.
About this task
  • When you create a LUN clone, automatic deletion of the LUN clone is enabled by default in System Manager.
    The LUN clone is deleted when ONTAP triggers automatic deletion to conserve space.
  • You cannot clone LUNs that are on SnapLock volumes.
Steps
  1. Click Storage > LUNs.
  2. In the LUN Management tab, select the LUN that you want to clone, and then click Clone.
  3. If you want to change the default name, specify a new name for the LUN clone.
  4. Click Clone.
  5. Verify that the LUN clone that you created is listed in the LUNs window.
Related information
