Clone an NVMe namespace with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to quickly create another namespace of the same configuration by choosing to clone a namespace. You can map the newly cloned namespace to another host NQN.
Before you begin
You must have a FlexClone license to clone a namespace.
About this task
You can clone a namespace with the selected host mapping and associate it with another subsystem.
Steps
  1. Click NVMe > NVMe namespaces.
  2. In the NVMe namespaces window, select the namespace you want to clone.
  3. You can rename the cloned namespace if you need a specific name but it is not required.
    The dialog provides a default name of the namespace to-be-cloned.
  4. Modify the subsystem mapping for the cloned namespace.
  5. Click OK.
    The online, mapped namespace is cloned inside the same SVM with a different name. Host mapping will not be cloned.
