Verify the restore operation
Contributors NetAppZacharyWambold netapp-thomi
After performing the restore operation from the SnapVault backup destination volume, you must verify the status of the restore operation on the source cluster.
About this task
You must perform this task from the source cluster.
Steps
  1. Navigate to the Volumes window.
  2. Select the source volume in the volumes list and perform one of the following actions, depending on your ONTAP version:
    • Beginning with ONTAP 9.3: Double-click the source volume to view the details, and then click PROTECTION to identify the destination volume in the SnapMirror relationship and the name of the SVM that contains the volume.
    • ONTAP 9.2 or earlier: Click the Data Protection bottom tab to identify the destination volume in the SnapMirror relationship and the name of the SVM that contains the volume. The Type field displays Restore temporarily. After the restore operation is completed, the field displays Vault.
      You should troubleshoot any issues in the SnapVault relationships. The troubleshooting procedures for SnapMirror relationships are also applicable to SnapVault relationships.
