Configuration requirements for Cisco Nexus 3232C switches
- PDF of this doc site
Creating your file...
For Cisco Nexus 3232C switch installation and maintenance, be sure to review configuration and network requirements.
To configure your cluster, you need the appropriate number and type of cables and cable connectors for your switches. Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable; you also need to provide specific network information.
Network requirements
You need the following network information for all switch configurations:
IP subnet for management network traffic
Host names and IP addresses for each of the storage system controllers and all applicable switches
Most storage system controllers are managed through the e0M interface by connecting to the Ethernet service port (wrench icon). On AFF A800 and AFF A700 systems, the e0M interface uses a dedicated Ethernet port.
Refer to the Hardware Universe for latest information.
