Install and maintain
Replace Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Contributors netapp-yvonneo netapp-jolieg
You can replace defective Nexus 9336C-FX2 and 9336C-FX2-T switches in a cluster network. This is a nondisruptive procedure.
Before you begin
Before installing the NX-OS software and RCFs on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches, ensure that:
  • Your system can support Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches.
  • You have consulted the switch compatibility table on the Cisco Ethernet Switch page for the supported ONTAP, NX-OS, and RCF versions.
  • You have referred to the appropriate software and upgrade guides available on the Cisco web site.
  • You have downloaded the applicable RCFs.
  • The existing network configuration has the following characteristics:
    • The Cisco Ethernet Switches page has the latest RCF and NX-OS versions on your switches.
    • Management connectivity must exist on both switches.
  • The replacement Cisco Nexus 9336C-FX2 switch has the following characteristics:
    • Management network connectivity is functional.
    • Console access to the replacement switch is in place.
    • The appropriate RCF and NX-OS operating system image is loaded onto the switch.
    • Initial configuration of the switch is complete.
About this task
This procedure replaces the second Nexus 9336C-FX2 storage switch s2 with the new 9336C-FX switch ns2. The two nodes are cluster1-01 and cluster1-02.
Steps to complete:
  • Confirm the switch to be replaced is s2.
  • Disconnect the cables from switch s2.
  • Reconnect the cables to switch ns2.
  • Verify all device configurations on switch ns2.
    Note There can be dependencies between command syntax in the RCF and NX-OS versions.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    x is the duration of the maintenance window in hours.
  2. Check on the health status of the storage node ports to make sure that there is connection to storage switch s1:
    storage port show -port-type ENET
    Show example
    storage::*> storage port show -port-type ENET
                                      Speed                     VLAN
    Node           Port Type  Mode    (Gb/s) State    Status      ID
    cluster1-01
                   e5a  ENET  storage 100    enabled  online      30
                   e3b  ENET  storage   0    enabled  offline     30
    cluster1-02
  3. Verify that storage switch s1 is available:
    network device-discovery show
    Show example
    storage::*> network device-discovery show
    Node/      Local Discovered
    Protocol   Port	 Device (LLDP: ChassisID)  Interface  Platform
    cluster1-01/cdp
               e5a   s1                        Ethernet1/1 NX9336C
               e4a   cluster1-02               e4a         AFF-A700
               e4e   cluster1-02               e4e         AFF-A700
    cluster1-01/lldp
               e5a   s1                        Ethernet1/1 -
               e4a   cluster1-02               e4a         -
               e4e   cluster1-02               e4e         -
    cluster1-02/cdp
               e3b   s1                        Ethernet1/2 NX9336C
               e4a   cluster1-01               e4a         AFF-A700
               e4e   cluster1-01               e4e         AFF-A700
    cluster1-02/lldp
               e3b   s1                        Ethernet1/2 -
               e4a   cluster1-01               e4a         -
               e4e   cluster1-01               e4e         -
  4. Run the show lldp neighbors command on the working switch to confirm that you can see both nodes and all shelves:
    show lldp neighbors
    Show example
    S1# show lldp neighbors
    Capability codes:
       (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
       (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
    Device ID        Local Intf   Hold-time    Capability    Port ID
    cluster1-01      Eth1/1       121          S             e5a
    cluster1-02      Eth1/2       121          S             e5a
    SHFGD2008000011  Eth1/5       121          S             e0a
    SHFGD2008000011  Eth1/6       120          S             e0a
    SHFGD2008000022  Eth1/7       120          S             e0a
    SHFGD2008000022  Eth1/8       120          S             e0a
  5. Verify the storage shelf ports in the storage system:
    storage shelf port show -fields remote-device,remote-port
    Show example
    storage::*> storage shelf port show -fields remote-device,remote-port
    shelf   id  remote-port   remote-device
    3.20    0   Ethernet1/5   s1
    3.20    1   -             -
    3.20    2   Ethernet1/6   s1
    3.20    3   -             -
    3.30    0   Ethernet1/7   s1
    3.20    1   -             -
    3.30    2   Ethernet1/8   s1
    3.20    3   -             -
  6. Remove all cables attached to storage switch s2.
  7. Reconnect all cables to the replacement switch ns2.
  8. Recheck the health status of the storage node ports:
    Show example
                                        Speed                     VLAN
    cluster1-01
                     e7a  ENET  storage   0    enabled  offline     30
                     e7b  ENET  storage   0    enabled  offline     30
    cluster1-02
  9. Verify that both switches are available:
    Show example
    cluster1-01/cdp
              e3a  s1                         Ethernet1/1 NX9336C
              e7b  ns2                       Ethernet1/1 NX9336C
    cluster1-01/lldp
              e3a  s1                         Ethernet1/1 -
              e7b  ns2                        Ethernet1/1 -
    cluster1-02/cdp
              e3a  s1                         Ethernet1/2 NX9336C
              e7b  ns2                        Ethernet1/2 NX9336C
    cluster1-02/lldp
              e3a  s1                         Ethernet1/2 -
              e7b  ns2                        Ethernet1/2 -
  10. Verify the shelf ports in the storage system:
    Show example
    3.20    1     Ethernet1/5     ns2
    3.20    3     Ethernet1/6     ns2
    3.20    1     Ethernet1/7     ns2
    3.20    3     Ethernet1/8     ns2
    storage::*>
  11. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've replaced your switches, you can configure switch health monitoring.
