Retire node1
PDF of this doc site
- Upgrade by using aggregate relocation
Creating your file...
Your file is ready
To retire node1, you resume the automated operation to disable the HA pair with node2 and shut node1 down correctly. Later in the procedure, you remove node1 from the rack or chassis.
Steps
Resume the operation:
system controller replace resume
Verify that node1 has been halted:
system controller replace show-details
After you finish
You can decommission node1 after the upgrade is completed. See Decommission the old system.
