Shut down the controllers - AFF A200
- PDF of this doc site
Creating your file...
This procedure is for 2-node, non-MetroCluster configurations only. If you have a system with more than two nodes, see How to perform a graceful shutdown and power up of one HA pair in a 4-node cluster.
You need:
Local administrator credentials for ONTAP.
NetApp onboard key management (OKM) cluster-wide passphrase if using storage encryption or NVE/NAE.
BMC accessability for each controller.
Stop all clients/host from accessing data on the NetApp system.
Suspend external backup jobs.
Necessary tools and equipment for the replacement.
If the system is a NetApp StorageGRID or ONTAP S3 used as FabricPool cloud tier, refer to the Gracefully shutdown and power up your storage system Resolution Guide after performing this procedure. |
If using SSDs, refer to SU490: (Impact: Critical) SSD Best Practices: Avoid risk of drive failure and data loss if powered off for more than two months |
As a best practice before shutdown, you should:
Perform additional system health checks.
Upgrade ONTAP to a recommended release for the system.
Resolve any Active IQ Wellness Alerts and Risks. Make note of any faults presently on the system, such as LEDs on the system components.
Log into the cluster through SSH or log in from any node in the cluster using a local console cable and a laptop/console.
Turn off AutoSupport and indicate how long you expect the system to be offline:
system node autosupport invoke -node * -type all -message "MAINT=8h Power Maintenance"
Identify the SP/BMC address of all nodes:
system service-processor show -node * -fields address
Exit the cluster shell:
exit
Log into SP/BMC over SSH using the IP address of any of the nodes listed in the output from the previous step.
If your're using a console/laptop, log into the controller using the same cluster administrator credentials.
Open an SSH session to every SP/BMC connection so that you can monitor progress. -
Halt the 2 nodes located in the impaired chassis:
system node halt -node <node>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true
For clusters using SnapMirror synchronous operating in StrictSync mode: system node halt -node <node>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true -ignore-strict-sync-warnings true
Enter y for each controller in the cluster when you see
Warning: Are you sure you want to halt node "cluster <node-name> number"? {y|n}:
Wait for each controller to halt and display the LOADER prompt.
