Shut down the controllers - AFF A220
- PDF of this doc site
Creating your file...
Shut down or take over the impaired controller using the appropriate procedure for your configuration.
Option 1: Most configurations
This procedure is for 2-node, non-MetroCluster configurations only. If you have a system with more than two nodes, see How to perform a graceful shutdown and power up of one HA pair in a 4-node cluster.
You need:
Local administrator credentials for ONTAP.
NetApp onboard key management (OKM) cluster-wide passphrase if using storage encryption.
SP/BMC accessability for each controller.
Stop all clients/host from accessing data on the NetApp system.
Suspend external backup jobs.
Necessary tools and equipment for the replacement.
If the system is a NetApp StorageGRID or ONTAP S3 used as FabricPool cloud tier, refer to the Gracefully shutdown and power up your storage system Resolution Guide after performing this procedure. |
If using FlexArray array LUNs, follow the specific vendor storage array documentation for the shutdown procedure to perform for those systems after performing this procedure. |
If using SSDs, refer to SU490: (Impact: Critical) SSD Best Practices: Avoid risk of drive failure and data loss if powered off for more than two months |
As a best practice before shutdown, you should:
Perform additional system health checks.
Upgrade ONTAP to a recommended release for the system.
Resolve any Active IQ Wellness Alerts and Risks. Make note of any faults presently on the system, such as LEDs on the system components.
Log into the cluster through SSH or log in from any node in the cluster using a local console cable and a laptop/console.
Turn off AutoSupport and indicate how long you expect the system to be off line:
system node autosupport invoke -node * -type all -message "MAINT=8h Power Maintenance"
Identify the SP/BMC address of all nodes:
system service-processor show -node * -fields address
Exit the cluster shell:
exit
Log into SP/BMC over SSH using the IP address of any of the nodes listed in the output from the previous step.
If your're using a console/laptop, log into the controller using the same cluster administrator credentials.
Open an SSH session to every SP/BMC connection so that you can monitor progress. -
Halt all nodes in the cluster:
system node halt -node * -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true
.For clusters using SnapMirror synchronous operating in StrictSync mode: system node halt -node * -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true -ignore-strict-sync-warnings true
Enter y for each controller in the cluster when you see
Warning: Are you sure you want to halt node "cluster name-controller number"? {y|n}:
Wait for each controller to halt and display the LOADER prompt.
Turn off each PSU or unplug them if there is no PSU on/off switch.
Unplug the power cord from each PSU.
Verify that all controllers in the impaired chassis are powered down.
Option 2: Controller is in a MetroCluster configuration
Do not use this procedure if your system is in a two-node MetroCluster configuration. |
To shut down the impaired controller, you must determine the status of the controller and, if necessary, take over the controller so that the healthy controller continues to serve data from the impaired controller storage.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (
metrocluster node show
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=number_of_hours_downh
The following AutoSupport message suppresses automatic case creation for two hours:
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
Disable automatic giveback from the console of the healthy controller:
storage failover modify –node local -auto-giveback false
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
y
when prompted.System prompt or password prompt (enter system password)
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name
When the impaired controller shows Waiting for giveback…, press Ctrl-C, and then respond
y
