Overview of chassis replacement - AFF A320
- PDF of this doc site
Creating your file...
Your file is ready
To replace the chassis, you must move the fans and controller modules from the impaired chassis to the new chassis of the same model as the impaired chassis.
All other components in the system must be functioning properly; if not, you must contact technical support.
You can use this procedure with all versions of ONTAP supported by your system.
This procedure is written with the assumption that you are moving the controller modules to the new chassis, and that the chassis is a new component from NetApp.
This procedure is disruptive. For a two-node cluster, you will have a complete service outage and a partial outage in a multi-node cluster.
