Install and maintain
Overview of chassis replacement - AFF A700
All other components in the system must be functioning properly; if not, you must contact technical support.
  • You can use this procedure with all versions of ONTAP supported by your system.
  • This procedure is disruptive. For a two-node cluster, you will have a complete service outage and a partial outage in a multi-node cluster.
