Shut down the controllers - AFF A700
To replace the chassis, you must shutdown the controllers.
Option 1: Shut down the controllers
This procedure is for 2-node, non-MetroCluster configurations only. If you have a system with more than two nodes, see How to perform a graceful shutdown and power up of one HA pair in a 4-node cluster.
You need:
Local administrator credentials for ONTAP.
NetApp onboard key management (OKM) cluster-wide passphrase if using storage encryption.
SP/BMC accessability for each controller.
Stop all clients/host from accessing data on the NetApp system.
Suspend external backup jobs.
Necessary tools and equipment for the replacement.
If the system is a NetApp StorageGRID or ONTAP S3 used as FabricPool cloud tier, refer to the Gracefully shutdown and power up your storage system Resolution Guide after performing this procedure. |
If using FlexArray array LUNs, follow the specific vendor storage array documentation for the shutdown procedure to perform for those systems after performing this procedure. |
If using SSDs, refer to SU490: (Impact: Critical) SSD Best Practices: Avoid risk of drive failure and data loss if powered off for more than two months |
As a best practice before shutdown, you should:
Perform additional system health checks.
Upgrade ONTAP to a recommended release for the system.
Resolve any Active IQ Wellness Alerts and Risks. Make note of any faults presently on the system, such as LEDs on the system components.
Log into the cluster through SSH or log in from any node in the cluster using a local console cable and a laptop/console.
Turn off AutoSupport and indicate how long you expect the system to be off line:
system node autosupport invoke -node * -type all -message "MAINT=8h Power Maintenance"
Identify the SP/BMC address of all nodes:
system service-processor show -node * -fields address
Exit the cluster shell:
exit
Log into SP/BMC over SSH using the IP address of any of the nodes listed in the output from the previous step.
If your're using a console/laptop, log into the controller using the same cluster administrator credentials.
Open an SSH session to every SP/BMC connection so that you can monitor progress. -
Halt all nodes in the cluster:
system node halt -node * -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true
.For clusters using SnapMirror synchronous operating in StrictSync mode: system node halt -node * -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true -ignore-strict-sync-warnings true
Enter y for each controller in the cluster when you see
Warning: Are you sure you want to halt node "cluster name-controller number"? {y|n}:
Wait for each controller to halt and display the LOADER prompt.
Turn off each PSU or unplug them if there is no PSU on/off switch.
Unplug the power cord from each PSU.
Verify that all controllers in the impaired chassis are powered down.
Option 2: Shut down a node in a two-node MetroCluster configuration
To shut down the impaired controller, you must determine the status of the controller and, if necessary, switch over the controller so that the healthy controller continues to serve data from the impaired controller storage.
You must leave the power supplies turned on at the end of this procedure to provide power to the healthy controller.
Check the MetroCluster status to determine whether the impaired controller has automatically switched over to the healthy controller:
metrocluster show
Depending on whether an automatic switchover has occurred, proceed according to the following table:
If the impaired controller… Then… Has automatically switched over
Proceed to the next step.
Has not automatically switched over
Perform a planned switchover operation from the healthy controller:
metrocluster switchover
Has not automatically switched over, you attempted switchover with the
command, and the switchover was vetoedReview the veto messages and, if possible, resolve the issue and try again. If you are unable to resolve the issue, contact technical support.
Resynchronize the data aggregates by running the
metrocluster heal -phase aggregates
command from the surviving cluster.controller_A_1::> metrocluster heal -phase aggregates [Job 130] Job succeeded: Heal Aggregates is successful.
If the healing is vetoed, you have the option of reissuing the
metrocluster heal
command with the-override-vetoes
parameter. If you use this optional parameter, the system overrides any soft vetoes that prevent the healing operation. -
Verify that the operation has been completed by using the metrocluster operation show command.
controller_A_1::> metrocluster operation show Operation: heal-aggregates State: successful Start Time: 7/25/2016 18:45:55 End Time: 7/25/2016 18:45:56 Errors: -
Check the state of the aggregates by using the
storage aggregate show
command.controller_A_1::> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ ... aggr_b2 227.1GB 227.1GB 0% online 0 mcc1-a2 raid_dp, mirrored, normal...
Heal the root aggregates by using the
metrocluster heal -phase root-aggregates
command.mcc1A::> metrocluster heal -phase root-aggregates [Job 137] Job succeeded: Heal Root Aggregates is successful
metrocluster heal
command with the -override-vetoes parameter. If you use this optional parameter, the system overrides any soft vetoes that prevent the healing operation. -
Verify that the heal operation is complete by using the
command on the destination cluster:mcc1A::> metrocluster operation show Operation: heal-root-aggregates State: successful Start Time: 7/29/2016 20:54:41 End Time: 7/29/2016 20:54:42 Errors: -
On the impaired controller module, disconnect the power supplies.
