Install and maintain
Maintain AFF A700 hardware
Contributors netapp-jsnyder
For the AFF A700 storage system, you can perform maintenance procedures on the following components.
Boot media
The boot media stores a primary and secondary set of boot image files that the system uses when it boots.
Caching module
You must replace the controller’s caching module when your system registers a single AutoSupport (ASUP) message that the module has gone offline.
Chassis
The chassis is the physical enclosure housing all the controller components such as the controller/CPU unit, power supply, and I/O.
Controller
A controller consists of a board, firmware, and software. It controls the drives and implements the ONTAP functions.
DCPM
The DCPM (destage controller power module) contains the NVRAM11 battery.
DIMM
You must replace a DIMM (dual in-line memory module) when a memory mismatch is present, or you have a failed DIMM.
Fan
The fan cools the controller.
I/O module
The I/O module (Input/Output module) is a hardware component that acts as an intermediary between the controller and various devices or systems that need to exchange data with the controller.
LED USB
The LED USB module provides connectivity to console ports and system status.
NVRAM
The NVRAM module (Non-Volatile Random Access Memory) allows the controller to retain data across power cycles or system reboots.
Power supply
A power supply provides a redundant power source in a controller shelf.
Real-time clock battery
A real time clock battery preserves system date and time information if the power is off.
X91148A module
The X91148A module is an I/O module that acts as an intermediary between the controller and various devices or systems that need to exchange data with the controller.
