Install and maintain
Replace an LED USB module - AFF A900
Contributors dougthomp netapp-martyh
The LED USB module provides connectivity to console ports and system status. Replacement of this module does not require tools and does not interrupt service.
Step 1: Replace the LED USB module
Steps
  1. Remove the old LED USB module:
    Animation - Remove/install LED-USB module
    drw a900 remove replace LED mod
    Callout number 1
    Locking button
    Callout number 2
    USB LED module
    1. With the bezel removed, locate the LED USB module at the front of the chassis, on the bottom left side.
    2. Slide the latch to partially eject the module.
    3. Pull the module out of the bay to disconnect it from the midplane. Do not leave the slot empty.
  2. Install the new LED USB module:
    1. Align the module to the bay with the notch in the corner of the module positioned near the slider latch on the chassis. The bay will prevent you from installing the module upside down.
    2. Push the module into the bay until it is fully seated flush with the chassis.
      There is an audible click when the module is secure and connected to the midplane.
Step 2: Return the failed component
  1. Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return & Replacements page for further information.
