Install and maintain
Shut down the controller - ASA C250
Contributors dougthomp netapp-jsnyder
Option 1: Most systems
Complete the shutdown of the impaired controller by halting it to the LOADER prompt and capturing the boot environment variables. The LOADER prompt is the safe halted state from which you can replace the boot media.
Steps
  1. Take the impaired controller to the LOADER prompt:
    If the impaired controller displays…​ Then…​
    The LOADER prompt
    Go to Remove controller module.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt (enter system password)
    Take over or halt the impaired controller from the healthy controller: storage failover takeover -ofnode impaired_node_name
    When the impaired controller shows Waiting for giveback…​, press Ctrl-C, and then respond y.
  2. From the LOADER prompt, enter: printenv to capture all boot environmental variables. Save the output to your log file.
    Note This command may not work if the boot device is corrupted or non-functional.
Option 2: Systems in a MetroCluster
After completing the NVE or NSE tasks, you need to complete the shutdown of the impaired controller.
Note Do not use this procedure if your system is in a two-node MetroCluster configuration.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
  • If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (metrocluster node show).
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=number_of_hours_downh
    The following AutoSupport message suppresses automatic case creation for two hours: cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
  2. Disable automatic giveback from the console of the healthy controller: storage failover modify –node local -auto-giveback false
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
What's next?
After shutting down the controller, you need to replace the boot media.
