Complete the restoration and replacement process - ASA C250
- PDF of this doc site
Creating your file...
You must verify the HA state of the chassis, and return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
Step 1: Verify and set the HA state of the chassis
You must verify the HA state of the chassis, and, if necessary, update the state to match your system configuration.
In Maintenance mode, from either controller module, display the HA state of the local controller module and chassis:
ha-config show
The HA state should be the same for all components.
If the displayed system state for the chassis does not match your system configuration:
Set the HA state for the chassis:
ha-config modify chassis HA-state
The value for HA-state can be one of the following:
ha
mcc
mccip
non-ha
Confirm that the setting has changed:
ha-config show
If you have not already done so, recable the rest of your system.
Reinstall the bezel on the front of the system.
Step 2: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return & Replacements page for further information.
