Install and maintain
Quick steps - ASA C250
Contributors netapp-jsnyder
The Installation and Setup instructions give graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this guide if you are familiar with installing NetApp systems.
Note The ASA A250 and ASA C250 use the same installation procedure as the AFF A250 system.
