Install and maintain
What's new for AFF, ASA and FAS systems
Contributors netapp-jsnyder netapp-martyh RSS
Learn about the new features for AFF, ASA and FAS systems.
New platform support
Platforms (with links to data sheets) Available beginning
ONTAP 9.13.1P1
ONTAP 9.13.1P1
ONTAP 9.13.P11
ONTAP 9.13.1
ONTAP 9.13.1
ONTAP 9.13.1
ONTAP 9.13.1
ONTAP 9.13.1
ONTAP 9.12.1P1
ONTAP 9.13.1 GA and later ONTAP releases
Note
These platforms are not supported with ONTAP 9.13.1 RC1.
Note
Do not attempt to install or boot your AFF A150 storage system with an unsupported version of ONTAP. If you attempt to install or boot your system with an unsupported version of ONTAP, ONTAP will allow it (ONTAP will not block the attempt). The consequence is that your AFF A150 storage system will come up as a FAS2750 storage system.
ONTAP 9.13.1 and later ONTAP releases
ONTAP 9.12.1P1
ONTAP 9.11.1P8
ONTAP 9.10.1P12
ONTAP 9.11.1
ONTAP 9.10.1P3
ONTAP 9.10.1
ONTAP 9.8
ONTAP 9.8
ONTAP 9.8
ONTAP 9.7
ONTAP 9.7
ONTAP 9.7
ONTAP 9.7
ONTAP 9.7
ONTAP 9.6
ONTAP 9.6
New switch support
Switches Description Available beginning
The NVIDIA IP SN2100 storage switch is supported in MetroCluster IP configurations that use the A900/FAS9500 platforms.
ONTAP 9.12.1
The NVIDIA IP SN2100 storage switch is supported in MetroCluster IP configurations that use the following platforms:
  • FAS500f/AFF A250
  • FAS8300/AFF A400
  • FAS8700
  • FAS9000/AFF A700
  • AFF A800
ONTAP 9.10.1P3
Supports a shared Infrastructure (Cluster, HA, and switch-attached storage) on the same pair of Cisco Nexus 9336C-FX2 switches, including support for MetroCluster IP configurations.
ONTAP 9.9.1
Cisco Nexus 9336C-FX2 cluster interconnect switch and storage switch support for AFF/FAS controllers, as well as for front-end data connectivity.
ONTAP 9.8
Broadcom BES-53248 cluster interconnect switch support for AFF/FAS controllers with 40/100GbE ports.
ONTAP 9.8
Cisco Nexus 100 GbE switch can be used as a dedicated storage switch to connect NS224 NVMe drive shelves to the following platforms:
  • AFF A800/AFF ASA A800
  • AFF A700/AFF ASA A700
  • AFF A400/AFF ASA A400
  • AFF A320
ONTAP 9.8
Broadcom BES-53248 cluster interconnect switch support for AFF/FAS controllers with 10/25GbE ports.
ONTAP 9.5P8
New adapter support
Adapter part number Description Category Available beginning
2-port 100GbE RoCE QSFP28
  • Storage
  • Networking
  • HA/MetroCluster
ONTAP 9.8
2-port 25GbE RoCE QSFP28
  • Networking
  • HA/MetroCluster
ONTAP 9.8
NVMe SSD Module (1 TB)
Core dump device
ONTAP 9.8
New shelf support
Shelves Available beginning
NS224
ONTAP 9.6
New hardware updates
Functionality Description and where to learn more Available beginning
Expanded platform support for NS224 drive shelves
The following platforms support NS224 drive shelves:
  • AFF A250/AFF ASA A250
  • FAS500f
ONTAP 9.8
Hot-adding 12Gb SAS shelves to 6Gb SAS storage stacks
A single speed transition from 6Gb to 12Gb in a SAS storage stack is now supported. This enables storage expansion of existing 6Gb stacks with 12Gb shelves.
ONTAP 9.7P4
ONTAP 9.6P9
ONTAP 9.5P14
