Determine and control a volume's space usage in a local tier (aggregate)
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can determine which FlexVol volumes are using the most space in a local tier (aggregate) and specifically which features within the volume.
The volume show-footprint
command provides information about a volume's footprint, or its space usage within the containing aggregate.
command shows details about the space usage of each volume in an aggregate, including offline volumes. This command bridges the gap between the output of the volume show-space
and aggregate show-space
commands. All percentages are calculated as a percent of aggregate size.
The following example shows the volume show-footprint
command output for a volume called testvol:
cluster1::> volume show-footprint testvol Vserver : thevs Volume : testvol Feature Used Used% -------------------------------- ---------- ----- Volume Data Footprint 120.6MB 4% Volume Guarantee 1.88GB 71% Flexible Volume Metadata 11.38MB 0% Delayed Frees 1.36MB 0% Total Footprint 2.01GB 76%
The following table explains some of the key rows of the output of the volume show-footprint
command and what you can do to try to decrease space usage by that feature:
Row/feature name |
Description/contents of row |
Some ways to decrease |
The total amount of space used in the containing aggregate by a volume's data in the active file system and the space used by the volume's Snapshot copies. This row does not include reserved space. |
The amount of space reserved by the volume in the aggregate for future writes. The amount of space reserved depends on the guarantee type of the volume. |
Changing the type of guarantee for the volume to |
The total amount of space used in the aggregate by the volume's metadata files. |
No direct method to control. |
Blocks that ONTAP used for performance and cannot be immediately freed. For SnapMirror destinations, this row has a value of |
The total amount of space reserved for file operation metadata. |
The total amount of space that the volume uses in the aggregate. It is the sum of all of the rows. |
Any of the methods used to decrease space used by a volume. |
