Enable SnapMirror on the Element cluster
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You must enable SnapMirror on the Element cluster before you can create a replication relationship. You can perform this task in the Element software web UI only.
Before you begin
The Element cluster must be running NetApp Element software version 10.1 or later.
SnapMirror can only be enabled for Element clusters used with NetApp ONTAP volumes.
About this task
The Element system comes with SnapMirror disabled by default. SnapMirror is not automatically enabled as part of a new installation or upgrade.
Once enabled, SnapMirror cannot be disabled. You can only disable the SnapMirror feature and restore the default settings by returning the cluster to the factory image. |
Steps
Click Clusters > Settings.
Find the cluster-specific settings for SnapMirror.
Click Enable SnapMirror.
