Enable SnapMirror on the Element source volume
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
You must enable SnapMirror on the Element source volume before you can create a replication relationship. You can perform this task in the Element software web UI only.
Before you begin
You must have enabled SnapMirror on the Element cluster.
The volume block size must be 512 bytes.
The volume must not be participating in Element remote replication.
The volume access type must not be “Replication Target”.
About this task
The procedure below assumes the volume already exists. You can also enable SnapMirror when you create or clone a volume.
Steps
Select Management > Volumes.
Select the button for the volume.
In the drop-down menu, select Edit.
In the Edit Volume dialog, select Enable SnapMirror.
Select Save Changes.
