Reactivate the original source volume
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can reestablish the original data protection relationship between the source and destination volumes when you no longer need to serve data from the destination.
The procedure below assumes that the baseline in the original source volume is intact. If the baseline is not intact, you must create and initialize the relationship between the volume you are serving data from and the original source volume before performing the procedure.
You must specify the Element source path in the form hostip:/lun/name
, where “lun” is the actual string “lun” and name
is the name of the Element volume.
Beginning with ONTAP 9.4, Snapshot copies of a LUN created while you are serving data from the ONTAP destination are automatically replicated when the Element source is reactivated.
Replication rules are as follows:
Only iSCSI LUNs are supported.
You cannot replicate more than one LUN from an ONTAP volume to an Element volume.
You cannot replicate a LUN from an ONTAP volume to multiple Element volumes.
Delete the original data protection relationship:
snapmirror delete -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name -policy policy
For complete command syntax, see the man page.
The following example deletes the relationship between the original source volume,
0005
at IP address 10.0.0.11, and the volume you are serving data from,volA_dst
onsvm_backup
:cluster_dst::> snapmirror delete -source-path 10.0.0.11:/lun/0005 -policy MirrorLatest -destination-path svm_backup:volA_dst
Reverse the original data protection relationship:
snapmirror resync -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name -policy policy
Although resync does not require a baseline transfer, it can be time-consuming. You might want to run the resync in off-peak hours.
The following example reverses the relationship between the original source volume,
0005
onsvm_backup
:cluster_dst::> snapmirror resync -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005 -policy MirrorLatest
Update the reversed relationship:
snapmirror update -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name
The command fails if a common Snapshot copy does not exist on the source and destination. Use
snapmirror initialize
to re-initialize the relationship.The following example updates the relationship between the volume you are serving data from,
volA_dst
onsvm_backup
, and the original source volume,0005
at IP address 10.0.0.11:cluster_dst::> snapmirror update -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005
Stop scheduled transfers for the reversed relationship:
snapmirror quiesce -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name
The following example stops scheduled transfers between the volume you are serving data from,
volA_dst
onsvm_backup
at IP address 10.0.0.11:cluster_dst::> snapmirror quiesce -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005
Stop ongoing transfers for the reversed relationship:
snapmirror abort -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name
The following example stops ongoing transfers between the volume you are serving data from,
volA_dst
onsvm_backup
at IP address 10.0.0.11:cluster_dst::> snapmirror abort -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005
Break the reversed relationship:
snapmirror break -source-path SVM:volume|cluster://SVM/volume -destination-path hostip:/lun/name
The following example breaks the relationship between the volume you are serving data from,
volA_dst
onsvm_backup
at IP address 10.0.0.11:cluster_dst::> snapmirror break -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005
Delete the reversed data protection relationship:
The following example deletes the reversed relationship between the original source volume,
0005
onsvm_backup
:cluster_src::> snapmirror delete -source-path svm_backup:volA_dst -destination-path 10.0.0.11:/lun/0005 -policy MirrorLatest
Reestablish the original data protection relationship:
snapmirror resync -source-path hostip:/lun/name -destination-path SVM:volume|cluster://SVM/volume
The following example reestablishes the relationship between the original source volume,
0005
at IP address 10.0.0.11, and the original destination volume,volA_dst
onsvm_backup
:cluster_dst::> snapmirror resync -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst
Use the snapmirror show
command to verify that the SnapMirror relationship was created. For complete command syntax, see the man page.
