Resynchronize a replication relationship
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You need to resynchronize a replication relationship after you make a destination volume writeable, after an update fails because a common Snapshot copy does not exist on the source and destination volumes, or if you want to change the replication policy for the relationship.
Although resync does not require a baseline transfer, it can be time-consuming. You might want to run the resync in off-peak hours.
You must specify the Element source path in the form hostip:/lun/name
, where “lun” is the actual string “lun” and name
is the name of the Element volume.
Resync the source and destination volumes:
snapmirror resync -source-path hostip:/lun/name -destination-path SVM:volume|cluster://SVM/volume -type XDP -policy policy
For complete command syntax, see the man page.
The following example resyncs the relationship between the source volume
0005
at IP address 10.0.0.11 and the destination volumevolA_dst
onsvm_backup
:cluster_dst::> snapmirror resync -source-path 10.0.0.11:/lun/0005 -policy MirrorLatest -destination-path svm_backup:volA_dst
