Delete an encrypted volume
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use the volume delete
command to delete an encrypted volume.
You must be a cluster administrator to perform this task. Alternately, you can be an SVM administrator to whom the cluster administrator has delegated authority. For more information, see delegate authority to run the volume move command.
The volume must be offline.
Delete an encrypted volume:
volume delete -vserver SVM_name -volume volume_name
For complete command syntax, see the man page for the command.
The following command deletes an encrypted volume named
vol1
:cluster1::> volume delete -vserver vs1 -volume vol1
Enter
yes
when you are prompted to confirm deletion.The system deletes the encryption key for the volume after 24 hours.
Use
volume delete
with the-force true
option to delete a volume and destroy the corresponding encryption key immediately. This command requires advanced privileges. For more information, see the man page.
You can use the volume recovery-queue
command to recover a deleted volume during the retention period after issuing the volume delete
command:
volume recovery-queue SVM_name -volume volume_name
