Enable external key management in ONTAP 9.6 and later (HW-based)
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use one or more KMIP servers to secure the keys the cluster uses to access encrypted data. You can connect up to four KMIP servers to a node. A minimum of two servers is recommended for redundancy and disaster recovery.
Beginning in ONTAP 9.11.1, you can add up to 3 secondary key servers per primary key server to create a clustered key server. For more information, see Configure clustered external key servers.
The KMIP SSL client and server certificates must have been installed.
You must be a cluster administrator to perform this task.
You must configure the MetroCluster environment before you configure an external key manager.
In a MetroCluster environment, you must install the KMIP SSL certificate on both clusters.
Configure key manager connectivity for the cluster:
security key-manager external enable -vserver admin_SVM -key-servers host_name|IP_address:port,... -client-cert client_certificate -server-ca-cert server_CA_certificates
The
command replaces thesecurity key-manager setup
command. You can run thesecurity key-manager external modify
command to change the external key management configuration. For complete command syntax, see the man pages. -
In a MetroCluster environment, if you are configuring external key management for the admin SVM, you must repeat the
command on the partner cluster.
The following command enables external key management for
cluster1
with three external key servers. The first key server is specified using its hostname and port, the second is specified using an IP address and the default port, and the third is specified using an IPv6 address and port:clusterl::> security key-manager external enable -key-servers ks1.local:15696,10.0.0.10,[fd20:8b1e:b255:814e:32bd:f35c:832c:5a09]:1234 -client-cert AdminVserverClientCert -server-ca-certs AdminVserverServerCaCert
Verify that all configured KMIP servers are connected:
security key-manager external show-status -node node_name -vserver SVM -key-server host_name|IP_address:port -key-server-status available|not-responding|unknown
The
command replaces thesecurity key-manager show -status
command. For complete command syntax, see the man page.cluster1::> security key-manager external show-status Node Vserver Key Server Status ---- ------- --------------------------------------- ------------- node1 cluster1 10.0.0.10:5696 available fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234 available ks1.local:15696 available node2 cluster1 10.0.0.10:5696 available fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234 available ks1.local:15696 available 6 entries were displayed.
