Enable encryption on an existing volume
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can use either the volume move start
or the volume encryption conversion start
command to enable encryption on an existing volume.
Beginning with ONTAP 9.3, you can use the
command to enable encryption of an existing volume "in place," without having to move the volume to a different location. ALternatively, you can use thevolume move start
command. -
For ONTAP 9.2 and earlier, you can use only the
volume move start
command to enable encryption by moving an existing volume.
Enable encryption on an existing volume with the volume encryption conversion start command
Beginning with ONTAP 9.3, you can use the volume encryption conversion start
After you start a conversion operation, it must be completed. If you encounter a performance issue during the operation, you can run the volume encryption conversion pause
command to pause the operation, and the volume encryption conversion resume
command to resume the operation.
You cannot use volume encryption conversion start to convert a SnapLock volume.
Enable encryption on an existing volume:
volume encryption conversion start -vserver SVM_name -volume volume_name
For the entire command syntax, see the man page for the command.
The following command enables encryption on existing volume
vol1
:cluster1::> volume encryption conversion start -vserver vs1 -volume vol1
The system creates an encryption key for the volume. The data on the volume is encrypted.
Verify the status of the conversion operation:
volume encryption conversion show
The following command displays the status of the conversion operation:
cluster1::> volume encryption conversion show Vserver Volume Start Time Status ------- ------ ------------------ --------------------------- vs1 vol1 9/18/2017 17:51:41 Phase 2 of 2 is in progress.
When the conversion operation is completed, verify that the volume is enabled for encryption:
volume show -is-encrypted true
The following command displays the encrypted volumes on
cluster1
:cluster1::> volume show -is-encrypted true Vserver Volume Aggregate State Type Size Available Used ------- ------ --------- ----- ---- ----- --------- ---- vs1 vol1 aggr2 online RW 200GB 160.0GB 20%
If you are using a KMIP server to store the encryption keys for a node, ONTAP automatically “pushes” an encryption key to the server when you encrypt a volume.
Enable encryption on an existing volume with the volume move start command
You can use the volume move start
command to enable encryption by moving an existing volume. You must use volume move start
in ONTAP 9.2 and earlier. You can use the same aggregate or a different aggregate.
Beginning with ONTAP 9.8, you can use
volume move start
to enable encryption on a SnapLock or FlexGroup volume. -
Beginning with ONTAP 9.4, if you enable “cc-mode” when you set up the Onboard Key Manager, volumes you create with the
volume move start
command are automatically encrypted. You need not specify-encrypt-destination true
Beginning with ONTAP 9.6, you can use aggregate-level encryption to assign keys to the containing aggregate for the volumes to be moved. A volume encrypted with a unique key is called an NVE volume (meaning it uses NetApp Volume Encryption). A volume encrypted with an aggregate-level key is called an NAE volume (for NetApp Aggregate Encryption). Plaintext volumes are not supported in NAE aggregates.
Beginning with ONTAP 9.14.1, you can encrypt an SVM root volume with NVE. For more information, see Configure NetApp Volume Encryption on an SVM root volume.
You must be a cluster administrator to perform this task, or an SVM administrator to whom the cluster administrator has delegated authority.
Move an existing volume and specify whether encryption is enabled on the volume:
To convert…
Use this command…
A plaintext volume to an NVE volume
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_name -encrypt-destination true
An NVE or plaintext volume to an NAE volume (assuming aggregate-level encryption is enabled on the destination)
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_name -encrypt-with-aggr-key true
An NAE volume to an NVE volume
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_name -encrypt-with-aggr-key false
An NAE volume to a plaintext volume
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_name -encrypt-destination false -encrypt-with-aggr-key false
An NVE volume to a plaintext volume
The following command converts a plaintext volume named
vol1
to an NVE volume:cluster1::> volume move start -vserver vs1 -volume vol1 -destination-aggregate aggr2 -encrypt-destination true
Assuming aggregate-level encryption is enabled on the destination, the following command converts an NVE or plaintext volume named
vol1
to an NAE volume:cluster1::> volume move start -vserver vs1 -volume vol1 -destination-aggregate aggr2 -encrypt-with-aggr-key true
The following command converts an NAE volume named
vol2
to an NVE volume:cluster1::> volume move start -vserver vs1 -volume vol2 -destination-aggregate aggr2 -encrypt-with-aggr-key false
vol2
to a plaintext volume:cluster1::> volume move start -vserver vs1 -volume vol2 -destination-aggregate aggr2 -encrypt-destination false -encrypt-with-aggr-key false
The following command converts an NVE volume named
vol2
View the encryption type of cluster volumes:
volume show -fields encryption-type none|volume|aggregate
The
encryption-type
field is available in ONTAP 9.6 and later.For the entire command syntax, see the man page for the command.
The following command displays the encryption type of volumes in
cluster2
:cluster2::> volume show -fields encryption-type vserver volume encryption-type ------- ------ --------------- vs1 vol1 none vs2 vol2 volume vs3 vol3 aggregate
Verify that volumes are enabled for encryption:
cluster2
:cluster2::> volume show -is-encrypted true Vserver Volume Aggregate State Type Size Available Used ------- ------ --------- ----- ---- ----- --------- ---- vs1 vol1 aggr2 online RW 200GB 160.0GB 20%
If you are using a KMIP server to store the encryption keys for a node, ONTAP automatically pushes an encryption key to the server when you encrypt a volume.
