Change the encryption key for a volume with the volume encryption rekey start command
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
It is a security best practice to change the encryption key for a volume periodically. Beginning with ONTAP 9.3, you can use the volume encryption rekey start
command to change the encryption key.
Once you start a rekey operation, it must complete. There is no returning to the old key. If you encounter a performance issue during the operation, you can run the volume encryption rekey pause
command to pause the operation, and the volume encryption rekey resume
command to resume the operation.
Until the rekey operation finishes, the volume will have two keys. New writes and their corresponding reads will use the new key. Otherwise, reads will use the old key.
You cannot use |
Change an encryption key:
volume encryption rekey start -vserver SVM_name -volume volume_name
The following command changes the encryption key for
vol1
on SVMvs1
:cluster1::> volume encryption rekey start -vserver vs1 -volume vol1
Verify the status of the rekey operation:
volume encryption rekey show
For complete command syntax, see the man page for the command.
The following command displays the status of the rekey operation:
cluster1::> volume encryption rekey show Vserver Volume Start Time Status ------- ------ ------------------ --------------------------- vs1 vol1 9/18/2017 17:51:41 Phase 2 of 2 is in progress.
When the rekey operation is complete, verify that the volume is enabled for encryption:
volume show -is-encrypted true
The following command displays the encrypted volumes on
cluster1
:cluster1::> volume show -is-encrypted true Vserver Volume Aggregate State Type Size Available Used ------- ------ --------- ----- ---- ----- --------- ---- vs1 vol1 aggr2 online RW 200GB 160.0GB 20%
