Commands for enabling and disabling storage failover
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
Use the following commands to enable and disable storage failover functionality.
If you want to… |
Use this command… |
Enable takeover |
Disable takeover |
You should only disable storage failover if required as part of a maintenance procedure. |
