How hardware-assisted takeover works
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Enabled by default, the hardware-assisted takeover feature can speed up the takeover process by using a node's remote management device (Service Processor).
When the remote management device detects a failure, it quickly initiates the takeover rather than waiting for ONTAP to recognize that the partner's heartbeat has stopped. If a failure occurs without this feature enabled, the partner waits until it notices that the node is no longer giving a heartbeat, confirms the loss of heartbeat, and then initiates the takeover.
The hardware-assisted takeover feature uses the following process to avoid that wait:
The remote management device monitors the local system for certain types of failures.
If a failure is detected, the remote management device immediately sends an alert to the partner node.
Upon receiving the alert, the partner initiates takeover.
System events that trigger hardware-assisted takeover
The partner node might generate a takeover depending on the type of alert it receives from the remote management device (Service Processor).
Alert |
Takeover initiated upon receipt? |
Description |
abnormal_reboot |
No |
An abnormal reboot of the node occurred. |
l2_watchdog_reset |
Yes |
The system watchdog hardware detected an L2 reset. |
loss_of_heartbeat |
No |
The remote management device is no longer receiving the heartbeat message from the node. |
periodic_message |
No |
A periodic message is sent during a normal hardware-assisted takeover operation. |
power_cycle_via_sp |
Yes |
The remote management device cycled the system power off and on. |
power_loss |
Yes |
A power loss occurred on the node. |
power_off_via_sp |
Yes |
The remote management device powered off the system. |
reset_via_sp |
Yes |
The remote management device reset the system. |
test |
No |
A test message is sent to verify a hardware-assisted takeover operation. |
