Manage protected operation requests
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
When administrators in a MAV approval group (MAV administrators) are notified of a pending operation execution request, they must respond with an approve or veto message within a fixed time period (approval expiry). If a sufficient number of approvals are not received, the requester must delete the request and make another.
Approval requests are identified with index numbers, which are included in email messages and displays of the request queue.
The following information from the request queue can be displayed:
- Operation
The protected operation for which the request is created.
- Query
The object (or objects) upon which the user wants to apply the operation.
- State
The current state of the request; pending, approved, rejected, expired, executed. If a request is rejected by one approver, no further actions are possible.
- Required approvers
The number of MAV administrators that are required to approve the request. A user can set the required-approvers parameter for the operation rule. If a user does not set the required-approvers to the rule, then the required-approvers from the global setting is applied.
- Pending approvers
The number of MAV administrators that are still required to approve the request for the request to be marked as approved.
- Approval expiry
The period within which a MAV administrator must respond to an approval request. Any authorized user can set the approval-expiry for an operation rule. If approval-expiry is not set for the rule, then the approval-expiry from the global setting is applied.
- Execution expiry
The period within which the requesting administrator must complete the operation. Any authorized user can set the execution-expiry for an operation rule. If execution-expiry is not set for the rule, then the execution-expiry from the global setting is applied.
- Users approved
The MAV administrators who have approved the request.
- User vetoed
The MAV administrators who have vetoed the request.
- Storage VM (vserver)
The SVM with which the request is associated with. Only the admin SVM is supported in this release.
- User requested
The username of the user who created the request.
- Time created
The time when the request is created.
- Time approved
The time when the request state changed to approved.
- Comment
Any comments that are associated with the request.
- Users permitted
The list of users permitted to perform the protected operation for which the request is approved. If
users-permitted
is empty, then any user with appropriate permissions can perform the operation.
All expired or executed requests are deleted when a limit of 1000 requests is reached, or when the expired time is greater than 8hrs for expired requests. Vetoed requests are deleted once they are marked as expired.
System Manager procedure
MAV administrators receive email messages with details of the approval request, request expiry period, and a link to approve or reject the request. They can access an approval dialog by clicking the link in the email or navigate to Events & Jobs>Requests in System Manager.
The Requests window is available when multi-admin verification is enabled, showing pending requests based on the user’s login ID and MAV role (approver or not).
Operation
Index (number)
Status (Pending, Approved, Rejected, Executed, or Expired)
Query (any parameters or values for the requested operation)
Requesting User
Request Expires On
(Number of) Pending Approvers
(Number of) Potential Approvers
MAV administrators have additional controls in this window; they can approve, reject, or delete individual operations, or selected groups of operations. However, if the MAV administrator is the Requesting User, they cannot approve, reject or delete their own requests.
CLI procedure
When notified of pending requests by email, note the request’s index number and approval expiry period. The index number can also be displayed using the show or show-pending options mentioned below.
Approve or veto the request.
If you want to… Enter this command Approve a request
security multi-admin-verify request approve nn
Veto a request
security multi-admin-verify request veto nn
Show all requests, pending requests, or a single request
security multi-admin-verify request { show | show-pending } [nn] { -fields field1[,field2…] | [-instance ] }
You can show all requests in the queue or only pending requests. If you enter the index number, only information for that is displayed. You can display information about specific fields (by using the
-fields
parameter) or about all fields (by using the-instance
parameter).Delete a request
security multi-admin-verify request delete nn
The following sequence approves a request after the MAV administrator has received the request email with index number 3, which already has one approval.
cluster1::> security multi-admin-verify request show-pending Pending Index Operation Query State Approvers Requestor ----- -------------- ----- ------- --------- --------- 3 volume delete - pending 1 julia cluster-1::> security multi-admin-verify request approve 3 cluster-1::> security multi-admin-verify request show 3 Request Index: 3 Operation: volume delete Query: - State: approved Required Approvers: 2 Pending Approvers: 0 Approval Expiry: 2/25/2022 14:32:03 Execution Expiry: 2/25/2022 14:35:36 Approvals: mav-admin2 User Vetoed: - Vserver: cluster-1 User Requested: julia Time Created: 2/25/2022 13:32:03 Time Approved: 2/25/2022 13:35:36 Comment: - Users Permitted: -
The following sequence vetoes a request after the MAV administrator has received the request email with index number 3, which already has one approval.
cluster1::> security multi-admin-verify request show-pending Pending Index Operation Query State Approvers Requestor ----- -------------- ----- ------- --------- --------- 3 volume delete - pending 1 pavan cluster-1::> security multi-admin-verify request veto 3 cluster-1::> security multi-admin-verify request show 3 Request Index: 3 Operation: volume delete Query: - State: vetoed Required Approvers: 2 Pending Approvers: 0 Approval Expiry: 2/25/2022 14:32:03 Execution Expiry: 2/25/2022 14:35:36 Approvals: mav-admin1 User Vetoed: mav-admin2 Vserver: cluster-1 User Requested: pavan Time Created: 2/25/2022 13:32:03 Time Approved: 2/25/2022 13:35:36 Comment: - Users Permitted: -
