Display information about the FPolicy passthrough-read connection status
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can display information about FPolicy passthrough-read connection status to external FPolicy servers (FPolicy servers) for the cluster or for a specified storage virtual machine (SVM). This information can help you determine which FPolicy servers have passthrough-read data connections and for which FPolicy servers the passthrough-read connection is disconnected.
If you do not specify any parameter, the command displays the following information:
SVM name
FPolicy policy name
Node name
FPolicy server IP address
In addition to displaying information about FPolicy connections on the cluster or a specific SVM, you can use command parameters to filter the command's output by other criteria.
You can specify the -instance
parameter to display detailed information about listed policies. Alternatively, you can use the -fields
parameter to display only the indicated fields in the command output. You can enter ?
after the -fields
parameter to find out which fields you can use.
Display filtered information about connection status between the node and the FPolicy server by using the appropriate command:
If you want to display connection status information about…
Enter the command…
FPolicy passthrough-read connection status for the cluster
vserver fpolicy show-passthrough-read-connection
FPolicy passthrough-read connection status for a specified SVM
vserver fpolicy show-passthrough-read-connection -vserver vserver_name
FPolicy passthrough-read connection status for a specified policy
vserver fpolicy show-passthrough-read-connection -policy-name policy_name
Detailed FPolicy passthrough-read connection status for a specified policy
vserver fpolicy show-passthrough-read-connection -policy-name policy_name -instance
FPolicy passthrough-read connection status for the status that you specify
vserver fpolicy show-passthrough-read-connection -policy-name policy_name -server-status status
The server status can be one of the following:-
connected
disconnected
The following command displays information about passthrough-read connections from all FPolicy servers on the cluster:
cluster1::> vserver fpolicy show-passthrough-read-connection FPolicy Server Vserver Policy Name Node Server Status --------------- ------------- ------------ ----------------- -------------- vs2.example.com pol_cifs_2 FPolicy-01 2.2.2.2 disconnected vs1.example.com pol_cifs_1 FPolicy-01 1.1.1.1 connected
The following command displays detailed information about passthrough-read connections from FPolicy servers configured in the “pol_cifs_1” policy:
cluster1::> vserver fpolicy show-passthrough-read-connection -policy-name pol_cifs_1 -instance Node: FPolicy-01 Vserver: vs1.example.com Policy: pol_cifs_1 Server: 1.1.1.1 Session ID of the Control Channel: 8cef052e-2502-11e3-88d4-123478563412 Server Status: connected Time Passthrough Read Channel was Connected: 9/24/2013 10:17:45 Time Passthrough Read Channel was Disconnected: - Reason for Passthrough Read Channel Disconnection: none
