Complete the FPolicy scope worksheet
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use this worksheet to record the values that you need during the FPolicy scope configuration process. If a parameter value is required, you need to determine what value to use for those parameters before you configure the FPolicy scope.
You should record whether you want to include each parameter setting in the FPolicy scope configuration and then record the value for the parameters that you want to include.
Type of information |
Required |
Include |
Your values |
Storage virtual machine (SVM) name |
Yes |
Yes |
Policy name |
Yes |
Yes |
Shares to include |
No |
Shares to exclude |
No |
Volumes to include |
No |
Volumes to exclude |
No |
Export policies to include |
No |
Export policies to exclude |
No |
File extensions to include |
No |
File extension to exclude |
No |
Is file extension check on directory enabled? |
No |
