Commands for managing local netgroups
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
You can manage local netgroups by loading them from a URI, verifying their status across nodes, displaying them, and deleting them.
If you want to… |
Use the command… |
Load netgroups from a URI |
Verify the status of netgroups across nodes |
Available at the advanced privilege level and higher. |
Display local netgroups |
Delete a local netgroup |
See the man page for each command for more information.
