Control NFS access over TCP and UDP
Contributors netapp-thomi
You can enable or disable NFS access to storage virtual machines (SVMs) over TCP and UDP by modifying the -tcp and -udp parameters, respectively. This enables you to control whether NFS clients can access data over TCP or UDP in your environment.
About this task
These parameters only apply to NFS. They do not affect auxiliary protocols. For example, if NFS over TCP is disabled, mount operations over TCP still succeed. To completely block TCP or UDP traffic, you can use export policy rules.
Note
You must turn off the SnapDiff RPC Server before you disable TCP for NFS to avoid a command failed error. You can disable TCP by using the command vserver snapdiff-rpc-server off -vserver vserver name.
Step
  1. Perform one of the following actions:
    If you want NFS access to be…​
    Enter the command…​
    Enabled over TCP
    vserver nfs modify -vserver vserver_name -tcp enabled
    Disabled over TCP
    vserver nfs modify -vserver vserver_name -tcp disabled
    Enabled over UDP
    vserver nfs modify -vserver vserver_name -udp enabled
    Disabled over UDP
    vserver nfs modify -vserver vserver_name -udp disabled
