Overview of supported NFS versions and clients
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
Before you can use NFS in your network, you need to know which NFS versions and clients ONTAP supports.
This table notes when major and minor NFS protocol versions are supported by default in ONTAP. Support by default does not indicate that this is the earliest version of ONTAP supporting that NFS protocol.
Version | Enabled by default |
NFSv3 |
Yes |
NFSv4.0 |
Yes, beginning with ONTAP 9.9.1 |
NFSv4.1 |
NFSv4.2 |
pNFS |
No |
For the latest information about which NFS clients ONTAP supports, see the Interoperability Matrix.
