Clone LUNs from an active volume
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can create copies of your LUNs by cloning the LUNs in the active volume. These FlexClone LUNs are readable and writeable copies of the original LUNs in the active volume.
A FlexClone license must be installed. This license is include with ONTAP One.
A space-reserved FlexClone LUN requires as much space as the space-reserved parent LUN. If the FlexClone LUN is not space-reserved, you must ensure that the volume has enough space to accommodate changes to the FlexClone LUN.
You must have verified that the LUNs are not mapped to an igroup or are written to before making the clone.
Use the
lun show
command to verify that the LUN exists.lun show -vserver vs1
Vserver Path State Mapped Type Size -------- ----------------- --------- --------- -------- ------- vs1 /vol/vol1/lun1 online unmapped windows 47.07MB
Use the
volume file clone create
command to create the FlexClone LUN.volume file clone create -vserver vs1 -volume vol1 -source-path lun1 -destination-path/lun1_clone
If you need the FlexClone LUN to be available for automatic deletion, you include
-autodelete true
. If you are creating this FlexClone LUN in a volume using semi-thick provisioning, you must enable automatic deletion for all FlexClone LUNs. -
Use the
lun show
command to verify that you created a LUN.lun show -vserver vs1
Vserver Path State Mapped Type Size -------- ----------------------- -------- -------- -------- ------ vs1 /vol/volX/lun1 online unmapped windows 47.07MB vs1 /vol/volX/lun1_clone online unmapped windows 47.07MB
