Configure volume provisioning options
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can configure a volume for thin provisioning, thick provisioning, or semi-thick provisioning.
Setting the -space-slo
option to thick
ensures the following:
The entire volume is preallocated in the aggregate. You cannot use the
volume create
orvolume modify
command to configure the volume's-space-guarantee
option. -
100% of the space required for overwrites is reserved. You cannot use the
volume modify
command to configure the volume's-fractional-reserve
option
option to semi-thick
volume create
orvolume modify
option. -
No space is reserved for overwrites. You can use the
volume modify
option. -
Automatic deletion of Snapshot copies is enabled.
Configure volume provisioning options:
volume create -vserver vserver_name -volume volume_name -aggregate aggregate_name -space-slo none|thick|semi-thick -space-guarantee none|volume
The
-space-guarantee
option defaults tonone
for AFF systems and for non-AFF DP volumes. Otherwise, it defaults tovolume
. For existing FlexVol volumes, use thevolume modify
command to configure provisioning options.The following command configures vol1 on SVM vs1 for thin provisioning:
cluster1::> volume create –vserver vs1 -volume vol1 -space-guarantee none
The following command configures vol1 on SVM vs1 for thick provisioning:
cluster1::> volume create –vserver vs1 -volume vol1 -space-slo thick
The following command configures vol1 on SVM vs1 for semi-thick provisioning:
cluster1::> volume create –vserver vs1 -volume vol1 -space-slo semi-thick
