Determine the correct volume and LUN configuration combination for your environment
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
Answering a few basic questions about your environment can help you determine the best FlexVol volume and LUN configuration for your environment.
About this task
You can optimize your LUN and volume configurations for maximum storage utilization or for the security of write guarantees. Based on your requirements for storage utilization and your ability to monitor and replenish free space quickly, you must determine the FlexVol volume and LUN volumes appropriate for your installation.
You do not need a separate volume for each LUN. |
Step
Use the following decision tree to determine the best volume and LUN configuration combination for your environment:
