View and manage SAN initiators and igroups
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use System Manager to view and manage initiator groups (igroups) and initiators.
The initiator groups identify which hosts are able to access specific LUNs on the storage system.
After an initiator and initiator groups are created, you can also edit them or delete them.
To manage SAN initiators groups and initiators, you can perform the following tasks:
View and manage SAN initiator groups
You can use System Manager to view a list of initiator groups (igroups). From the list, you can perform additional operations.
In System Manager, click Hosts > SAN Initiator Groups.
The page displays a list of initiator groups (igroups). If the list is large, you can view additional pages of the list by clicking the page numbers at the lower right corner of the page.
The columns display various information about the igroups. Beginning with 9.11.1, the connection status of the igroup is also displayed. Hover over status alerts to view details.
(Optional): You can perform the following tasks by clicking the icons at the upper right corner of the list:
Search
Download the list.
Show or Hide columns in the list.
Filter the data in the list.
You can perform operations from the list:
Click to add an igroup.
Click the igroup name to view the Overview page that shows details about the igroup.
On the Overview page, you can view the LUNs associated with the igroup, and you can initiate the operations to create LUNs and map the LUNs. Click All SAN Initiators to return to the main list.
Hover over the igroup, then click next to an igroup name to edit or delete the igroup.
Hover over the area to the left of the igroup name, then check the check box. If you click +Add to Initiator Group, you can add that igroup to another igroup.
In the Storage VM column, click the name of a storage VM to view details about it.
You can use System Manager to view a list of initiators. From the list, you can perform additional operations.
To view initiators, perform the following:
Click the FC Initiators tab to view a list of FC initiators.
Click the iSCSI Initiators tab to view a list of iSCSI initiators.
The columns display various information about the initiators.
Beginning with 9.11.1, the connection status of the initiator is also displayed. Hover over status alerts to view details.
Search the list for particular initiators.
Download the list.
