Move a SAN LIF
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
If a node needs to be taken offline, you can move a SAN LIF to preserve its configuration information, such as its WWPN, and avoid rezoning the switch fabric. Because a SAN LIF must be taken offline before it is moved, host traffic must rely on host multipathing software to provide nondisruptive access to the LUN. You can move SAN LIFs to any node in a cluster, but you cannot move the SAN LIFs between storage virtual machines (SVMs).
If the LIF is a member of a port set, the LIF must have been removed from the port set before the LIF can be moved to a different node.
The destination node and physical port for a LIF that you want to move must be on the same FC fabric or Ethernet network. If you move a LIF to a different fabric that has not been properly zoned, or if you move a LIF to an Ethernet network that does not have connectivity between iSCSI initiator and target, the LUN will be inaccessible when you bring it back online.
View the administrative and operational status of the LIF:
network interface show -vserver vserver_name
Change the status of the LIF to
down
(offline):network interface modify -vserver vserver_name -lif LIF_name -status-admin down
Assign the LIF a new node and port:
network interface modify -vserver vserver_name -lif LIF_name -home-node node_name -home-port port_name
up
(online):network interface modify -vserver vserver_name -lif LIF_name -status-admin up
Verify your changes:
