Recommended volume and file or LUN configuration combinations overview
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
There are specific combinations of FlexVol volume and file or LUN configurations you can use, depending on your application and administration requirements. Understanding the benefits and costs of these combinations can help you determine the right volume and LUN configuration combination for your environment.
The following volume and LUN configuration combinations are recommended:
Space-reserved files or LUNs with thick volume provisioning
Non-space-reserved files or LUNs with thin volume provisioning
Space-reserved files or LUNs with semi-thick volume provisioning
You can use SCSI thin provisioning on your LUNs in conjunction with any of these configuration combinations.
Benefits:
All write operations within space-reserved files are guaranteed; they will not fail due to insufficient space.
There are no restrictions on storage efficiency and data protection technologies on the volume.
Costs and limitations:
Enough space must be set aside from the aggregate up front to support the thickly provisioned volume.
Space equal to twice the size of the LUN is allocated from the volume at LUN creation time.
Benefits:
Space is allocated only as it is used.
Costs and restrictions:
Write operations are not guaranteed; they can fail if the volume runs out of free space.
You must manage the free space in the aggregate effectively to prevent the aggregate from running out of free space.
Benefits:
Less space is reserved up front than for thick volume provisioning, and a best-effort write guarantee is still provided.
Write operations can fail with this option.
You can mitigate this risk by properly balancing free space in the volume against data volatility.
You cannot rely on retention of data protection objects such as Snapshot copies and FlexClone files and LUNs.
You cannot use ONTAP block-sharing storage efficiency capabilities that cannot be automatically deleted, including deduplication, compression, and ODX/Copy Offload.
