Change the FC adapter speed
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You should set your adapter target port speed to match the speed of the device to which it connects, instead of using autonegotiation. A port that is set to autonegotiation can take longer time to reconnect after a takeover/giveback or other interruption.
All LIFs that use this adapter as their home port must be offline.
Because this task encompasses all storage virtual machines (SVMs) and all LIFs in a cluster, you must use the -home-port
and -home-lif
parameters to limit the scope of this operation. If you do not use these parameters, the operation applies to all LIFs in the cluster, which might not be desirable.
Take all of the LIFs on this adapter offline:
network interface modify -vserver * -lif * { -home-node node1 -home-port 0c } -status-admin down
Take the adapter offline:
network fcp adapter modify -node node1 -adapter 0c -state down
If the adapter does not go offline, you can also remove the cable from the appropriate adapter port on the system.
Determine the maximum speed for the port adapter:
fcp adapter show -instance
You cannot modify the adapter speed beyond the maximum speed.
Change the adapter speed:
network fcp adapter modify -node node1 -adapter 0c -speed 16
Bring the adapter online:
network fcp adapter modify -node node1 -adapter 0c -state up
Bring all of the LIFs on the adapter online:
network interface modify -vserver * -lif * { -home-node node1 -home-port 0c } -status-admin up
