Commands for managing FC adapters
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can use FC commands to manage FC target adapters, FC initiator adapters, and onboard FC adapters for your storage controller. The same commands are used to manage FC adapters for the FC protocol and the FC-NVMe protocol.
FC initiator adapter commands work only at the node level. You must use the run -node node_name
command before you can use the FC initiator adapter commands.
Commands for managing FC target adapters
If you want to… | Use this command… |
Display FC adapter information on a node |
Modify FC target adapter parameters |
Display FC protocol traffic information |
Display how long the FC protocol has been running |
Display adapter configuration and status |
Verify which expansion cards are installed and whether there are any configuration errors |
View a man page for a command |
Commands for managing FC initiator adapters
Display information for all initiators and their adapters in a node |
Commands for managing onboard FC adapters
Display the status of the onboard FC ports |
